RE: three yard range
Hi Cheap,
I'm sure you replaced the tx bateries with fresh ones....but also check the battery wirting for cleanliness and bad connections or soldering. Try a different set of cyrstals. and make sure the TX is wired to the ant. inside the radio.
Good luck, Bob
