ORIGINAL: gr�nnskolling
I just got my A9 yesterday and was verry keen to try it out today...... but my servos moves like they are glued. Verry slow and choppy. They start to move 1-2 sek after I have moved the stik. The same with the motor, but the power is ok. I use the ESC as the battery. With my old 35 mhz recivers I had no problems like this at all.
Any ideas what I might do wrong?
I've seen this a couple of times... Try rebinding, that should take care of it. Sometimes this can happen is you switch between Normal and Scan mode and turn off the power before it finishes the process. If this is the case it could take two or three times to try to rebind it if it doesn't take the first time.
ORIGINAL: boex
I am looking for a new radio. I am considering the Futaba 8FG and the A9. The Futaba, as I understand it, comes with 8 proportional channels plus 2 switch channels, 10 channels in total. How many channels are proportional and how many are switch on the A9?
9 fully assignable proportional channels.
Optima 9 RX: $99.99
Futaba 6008HS: $139.99
If you want to use either of the 2 switchable channels on the 8FG, I believe you will need the 6014HS @ $199.99.
ORIGINAL: WILDCRASHWILLY
Guys,
I ordered my extra receivers about three weeks ago. I was wondering how long some of you have waited on your rx promotions and how was it shipped, UPS, USPS, or Fed Ex?
Coupons received prior to Feb 11th have been filled... any received after that are waiting on stock which is due later this week.
Mike.
