RCU Forums - View Single Post - Difference between 4.8v and 6.0v?
Old 03-22-2010 | 07:05 AM
  #32
CGRetired's Avatar
CGRetired
Default RE: Difference between 4.8v and 6.0v?
Thus the basic reasoning behind using a Voltwatch2. It does exactly that but does it all the time. So, after you turn everything on, get ready, start the engine, tune it, then range check it, by the time you get back from the range check, your "surface charge" should be consumed and it will give you what remains. Perfect application for Voltwatch2.
CGr.
