RE: Spec class spring mods.
You want to disassemble the shock and put 1/4 to 1/2 inch of fuel tubing on the shock shaft INSIDE the shock body under the piston. This will shorten them up a little and because they are progressive rate they will get into the stiffer part of the spring faster.
