RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Thread
03-23-2010 | 09:34 AM
665
FlyEng
My Feedback: (
5
Apr 2005
123
Tavares, FL
RE: SAP 180 (Syssa Performance)
Here are the photos of my work in progress. Lots on work still to do. I still need to reinforce the boxmount connections with small dowels or screws, fuel proofing, throttle and choke controls, lengthening the pipe tunnel and reshaping the formers, fuel plumbing,andfixing out of square wing tube. Yep, it's off almost a 1/2 cm from side to side measured at the ends of the wing tube. Thatputsthe adjustment at about 3mm for each end. Does anyone know a good way to loosen up the glue at the wing tube brackets inside the fuselage?Would heat do it? Obviously with the ARC version the covering isn't an issue at least notyet.
I decided to leave the box extending through the former inside the fuselage. I think this will make a good place to mount the ignition components. Besides, if i don't like it or don't use it, I can cut it out later.
Any suggestions are welcome.
Reply
Like
FlyEng
View Public Profile
Send a private message to FlyEng
Find More Posts by FlyEng
View iTrader Profile
