RE: Motors and Batteries
You are correct it does say it has a BEC and the high voltage of the 11.1volt Lipo pack is to much. So I guess if I am going to do this Ihave to use the Nicads. I dont want to use the motor which came with it because is extreamly heavy and the design of the glider restricts the lenght of the prop I can use, unless the pylon gets very high above the fuselage. I wanted to use a ducted fan because I can blend it into the contour of the fuselage, if I can find one 50 mm in diameter or smaller. Which still has the thrust I need.Do you have a schematic or wiring diagram which showsthepower connections? I do thank you and anyone elseforyour help.
Regards
Dan
