RCU Forums - View Single Post - DP Edge 540
Thread: DP Edge 540
Old 07-26-2003 | 02:28 PM
mrc100
Default DP Edge 540
I always harden the screw holes with thin CA after the initial servo mount. The screws did not seperate.
I had similar thoughts about adding a screw from the outside...or creating more surface area for the bond. I chose to use cloth and epoxy and it appears to be much stronger. I also used a small amount of cloth and epoxy inside the wing to secure the plywood mounts to the wing.
Mike
