RCU Forums - View Single Post - Ignition timing
Old 03-25-2010 | 11:18 AM
kingspark
Default RE: Ignition timing
A easy way to verify the angle:
"By light of spark to verify the angle"
First,screw out the plug,make it eay to rotate the shaft,and drag the HT wire near the shaft,then turn off the lamp darken the entironment, rotate the shaft,make the HT spark onto the shaft.
you will see the firing angle pretty clearly.
