Crooked tail
I've seen (and built) worse. The stab and fin look pretty good, problem is alignment to the wing. I would fly and see how it goes.
If it is too bad, you can correct the allignment of the wing by adding extra layers of wing seat tape to the right hand side to lower that side of the wing. That is what I used to do until I learned that you should check the alignment before glueing anything.
