Ok I see how things go from this link.
http://www.empirerc.com/motorwiring.htm
Istill do not know the Amp rateing Any Ideas.... This is all I could get from the Manufacturer.
Thanks Again
<font size="2" face="Arial"><p align="left">DUO Brushless Motor, (13.5 Turn).</p><p align="left">Features: TrinityOld Stock Class turn equivalent brushless motors for the ROAR and IFMAR brushless spec classes. The DUO motors feature adjustable timing, sintered rotor, heavy duty precision ball bearings, and a light weight aluminum can. The best part is the DUO motors may be used with either sensor or sensorless speed controls. This allows the racer to run what is the best speed controller. You are no longer locked into one type or manufacturer of speed controls.
Includes: (1) Duo Brushless Motor, (13.5), Equivalent to the old ROAR rules and comes with a sensor wire.
Requires: Installation in vehicle with appropriate motor screws, pinion andattaching the speed controller wires to the correct tabs on the motor.
Specifications: Length: 2.1" or 52.5mm,Can Diameter: 1.4" or 36mm,Shaft Diameter: 0.12" or 3.2mm.</p></font>
