RE: adjust the CG or trim
This being a beginner site I think it is important to add that checking th cg this way only works on symmetrical airfoils. If you try this with a semi or flat bottom you will be chasing the cg issue until you finally make it to unstable to fly. Most trainer and sport planes (not stunt or 3D) work best at the factory settings.
