RCU Forums - View Single Post - Using Butchered Servos
Old 03-26-2010 | 08:12 AM
cyclops2's Avatar
cyclops2
Default RE: Using Butchered Servos
Some companies allow you to JUST pull off the small gears & turn the arm of the plastic potentiometer shaft to neutral. With the transmitter stick &trim at stop.
The motor speed is then VERY smooth and directly equal to your speed stick movement.
I have don this to many different sized servos.
Servos are THE ONLY ...F & R ESCs ....for 6" to 9 " boats like the Lindburg LCP.
