RCU Forums - View Single Post - Poulan 42cc installing EI need help!
Old 03-27-2010 | 01:09 PM
flyrc100
My Feedback: (131)
Default RE: Poulan 42cc installing EI need help!
Pretty clever way to adjust the timing, was the ring holding the magnet made to fit the Crank Taper? I guess to adjust the timing you would loosen the prop hub, loosen the bolt on the magnet ring, rotate it to suit, then tighten everything back up?
