RCU Forums - View Single Post - Poulan 42cc installing EI need help!
Old 03-27-2010 | 01:53 PM
av8tor1977's Avatar
av8tor1977
Default RE: Poulan 42cc installing EI need help!
I think it is even easier than that. I believe the magnet ring just clamps around the prop adapter. You just loosen the pinch nut and rotate the ring, around the prop adapter, to adjust the timing. I have made a number of prop adapter setups similar to this.
AV8TOR
