RE: Anyone using the Hitec Eclipse 7 for heli?
Update, got the gyro thing worked out. If you use channel 7 for the gyro you then can adjust the gain by setting the EPA of channel 7. This will control the gain.
Now if I can just figure out why st2 mode causes 2 of the swach servos to move. Again all curves and trims are the same for the other 2 modes (normal and st1)
Larry
