RCU Forums - View Single Post - Elevator options
Old 04-06-2002 | 02:31 AM
can773's Avatar
can773
Default Re: Bellcrank
Originally posted by TOYMAKER
I havent tried the bellcrank method yet. I'm sure it has its advantages especially with a removable stab. However, wouldnt a pull/pull setup be lighter then a pushrod and bellcrank with rods and clevises?
Yes, but you will be saving very little, there are places that a lot more weight can be saved without the hassles of pull-pull. My current FG/foam/balsa 2M pattern ships are running at 9.6 lbs, no Duralites.
