Hitec eclipse 7 issues
Maybe some can answer and correct this problem I am having with my Eclipse 7 in Heli mode.
I am setting up my 450 using the Eclipse 7 transmitter. All is good untill it comes to the 3 different flt modes.
I first set all dual rates off, Inn all mixing modes, and swash setting are equal in all modes.
The throttle and pitch curves are identical in all 3 modes.
In normal postion all is good, swash pitch is ok and normal operation.
In ST1 mode all is good, swash pitch is ok and normal operation.
In ST2 mode 2 of the swash servos will move out of plane and cause the pitch to rise and alerion servo of drop about 2 degrees off level plane.
Also when the Flt cond switch is moved forward ST3 will also make the servos go off center.
I have checked all trim, sub trim, dual rates, EPA points, prog mixes 1 and 2, throttle and pitch curves and cannot find where any changes to the setting have changes in these 2 modes.
Any ideas where or what I am do to get all modes the same?
Larry
