RE: Opinions as beginner plane?
A brushless motor tends to produce more power and flight time.
It also does not have carbon "brushes" which wear out over time.
However that said, it is likely that a brushed motor will outlast the plane itself.
But it's a decent enough beginner's plane which you should do well with.
Try to fly it with the ailerons installed so you start off "right".
