RCU Forums - View Single Post - Throttle pushrod
Old 03-28-2010 | 07:47 PM
opjose's Avatar
opjose
Default RE: Throttle pushrod
ORIGINAL: SeamusG
When using an EZ connector do you use a spot of Loctite blue on the threads of the adjusting screw?
Absolutely!
When I've seen people having problems with EZ connectors, I most often find that they have failed to put on lock-tite.
I think this is a MUST with them.
Most grub screws do a pretty good job at digging into the metal rod, making it immobile, so I've never had to try grinding a tiny bit of metal off, to form a flat spot, as a may do with axles.
On planes that I worry about possible slipping, I may add the second collet/collar for safety.
On pull-pull tail assemblies with the servo on the tail, I don't bother as if one were to slip, the other is there to hold the rudder for landing.... as in the following image...
I do periodically check for slop and tightness just to be safe.
Frankly the EZ-Connector is much stronger than the clevises on the rudder above.
