RCU Forums - View Single Post - Axe CP Flight Issues
Old 03-28-2010 | 10:25 PM
CarGuy7a
Default RE: Axe CP Flight Issues
ORIGINAL: dragus359
Ah, I see. I never thought of using idle up to stabilize it in forward flight. Thanks for the tip. I wish there were another way though, because idle up flight drains the batteries much quicker than normal flight :-(
Yeah no doubt to that. It'll kill the flight times. You can also play with the pitch knob on the Tx if you still are running the stock radio. If you turn it towards the negative - side, it'll slightly give you a little more head speed. I usually run mine in the 50/50 position and as the battery starts draining down near the end of the flight, I'll turn the knob negative.
