RE: Throttle pushrod
definatly if properly installed with the metal keeper there not coming off, you need to destroy the keeper to get it off a servo horn,I use the rubber keepers for temporary installations to make sure the push rod is working properly, so its easy to adjust from hole to hole, when I am satisfied with the operation I then use the metal ones.
