RE: Throttle pushrod
opjose wrote "If anything the star wheels are impossible to remove or loosen without destroying them. "
I discussed this issue with the DuBro rep at the AMA show one year.
He emphatically stated to NOT reuse the clips. Then you are asking for trouble.
I use the easy connectors regularly, I've never had a problem and I do follow his advice.
Good Luck,
KW_Counter
