ORIGINAL: Korps
What happened was, the little screw/plug thingy which is on the carb where the pushrod gets tied down to broke off - at WOT can you believe it?
Sure. Not only can I believe it but I have come to expect it from those little failure points. I check mine after every trip to the field. Throttle and nose-wheel steering is the only place I use those. And even then I shy away from them. But for some applications they certainly are handy.
