ORIGINAL: KW_Counter
opjose wrote ''If anything the star wheels are impossible to remove or loosen without destroying them. ''
I discussed this issue with the DuBro rep at the AMA show one year.
He emphatically stated to NOT reuse the clips. Then you are asking for trouble.
I use the easy connectors regularly, I've never had a problem and I do follow his advice.
Good Luck,
KW_Counter
Yup, I agree. Why invite problems?
The point of the statement though was how hard they are to remove even when you do not want to re-use them.
I find that I have to cut off the star wheels to remove the EZ connector from the horn.
