RCU Forums - View Single Post - Making a servo move slower?
Old 03-29-2010 | 12:45 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Making a servo move slower?
ORIGINAL: LNEWQBAN
Additional reducing gears would slow the final output movement down, increasing the output torque as well: a win-win solution, I believe.
The problem is: Where would you put them? They won't fit inside the case and they won't work outside the case.
ORIGINAL: LNEWQBAN
Why aren't those servos made slower in that simple way, just designing them with a couple of additinal gear wheels?[sm=confused.gif]
Because they make the servos with a low profile so they will sit below the surface of the wing, so, there really isn't room in that little box to PUT any more gears.
