Mark,
I see you doing some homework here... Must mean you're deep in thought in getting a 500 size. Me too, but it's gonna be next summer before I do that. I've got a Bell 206 Scale heli I'm gonna be working on for the 450 size. It'll be my first scaler and I'm looking forward to the build.
One thing to keep in mind on a 500 size heli, is that your cyclic servos are a bit more expensive and so will the batteries. For the 500L motor, you should be running at least a 5S 3,000 mAh battery, and for best performance a 6S battery. If you don't have a charger that is capable of charging a 5S or 6S battery, add that to you list also.
Don't forget the Trex 700E will be out in a month or so. LOL!
Dave
ORIGINAL: Aframomum
Hi guys,
If anyone is interested I have been looking into a 500 and getting basic info on Align's and on clones. Here's what I found:
TRex 500 Types:
500CF ESP Superior Combo Kit $529.95 (Readyheli)
60A BL ESC w/ built in 5-6V BEC, 500L motor (12T and 13T pinions)
CF frames, all metal upgrades, and TT
3 – DS510 digital servos, 425mm CF main blades, multicolored canopy
…only kit that advertises metal parts…
(Heli, ESC, 500L Motor, TT, cyclic servo’s, CF blades)
Requires: Gyro, Tail servo, Receiver, and Lipo battery
500CF Kit $399.95 (helidirect)
60A BL ESC, 500L motor (12T and 13T pinions)
CF frames, belt driven tail, needs metal upgrades
425mm CF main blades, yellow canopy
500GF Kit $399.99
60A BL ESC, 500L motor (13T pinion)
Fiberglass frames (silver), belt driven tail, needs metal upgrades
425 fiberglass blades, red canopy
TRex 500 Clones:
HK -500 EP $49.99 (Hobbycity)
Barebones kit, white canopy
Metal frame, 98% compatible w/ Trex 500 parts
Plastic head, tail, and bearing block
Belt driven
HK -500 GT $67.29 (Hobbycity)
Barebones kit, painted canopy
Metal frame, 100 % compatible w/ Trex parts
All metal head and metal bearing block
Plastic tail, belt driven
Copter X CX500 $124.99 (eHirobo)
CF frame, metal head, metal tail, and metal bearing block
Belt driven
EXI 500 $139.00 (Xheli)
Belt driven
Parts:
Copter X 500 metal head: $97.02 (eHirobo)
TT conversion kit: $81.00 (readyheli)
CF blades 425mm: $7.77 – $19.95 (Hobbycity)
Mark
