ORIGINAL: twostroke
Make sure if you go with a kit to go laser cut I am just finishing a Great Planes PT-20 for something to do and it is die-cut ''I WILL NEVER BUILD A DIE CUT KIT AGAIN'' they suck, fit is terrible and you have to be so careful with the small parts coming outof sheets, I had to modify the wing saddle just to fit the wing- thats not right wing was built over the plan and the fuselage is just glue together-never again with the die-cuts....
Big Girl!!!!
Yep, a Stick, we always forget the Stick!!
