RCU Forums - View Single Post - Hobbico Avistar - OS .46 LA Engine Mounting Problem
Old 07-17-2003 | 03:28 AM
Borzak
Default Hobbico Avistar - OS .46 LA Engine Mounting Problem
I have an avistar I just finished with an O.S. 46 LA and the only problem I had was I had to put the clevis in the nearest hole to the rotation of the throttle. If you put it to the outside hold it would catch on the motor mount.
I had too much travel with it located in the near hole but I fixed it the lazy/bad way with the radio EPA.
