RE: A question about 5 min. epoxy.
HI IF THE wing was joined straight and correctly you will have no problem with it holding together as all epoxy is very strong-if you still have air pockets (no epoxy ) that you can see in the wing seam fill them with thick CA now. Drying time should not be an issue as the parts should have been prepared to fit-several times before you apply any epoxy (lined up and marked before epoxy is applied ) s/b just a matter of holding them together until epoxy sets-i tack glue with thick CA and a kicker to hold the position desired until the epoxie sets5 minutes is a long time if the parts are properly in line as they should be fit twice mark and glue once -should get it rightTHE DIFFERENCE BETWEEN A GOOD BUILDER AND ONE THAT IS NOTIS THE GOOD BUILDER WILL CORRECT WHAT HE DID WRONG BEFORE MOVING FOWARDJUST TAKE IT APART AND REDO just my .02 ENJOY REGARDS TONY
