RE: 1/3 Scale Halberstadt D.III
Seth:
That doesn't make much sense to run the cables on each side of the strut? I have tried looking at old photo's with an eye loupe to see if I can get some small detail figured out but no luck so far on this one. I have used the nylon tubes quit a few times with no problems. The tubes stop at the root rib, then enter the fuse on their own without any other tube. The angular difference with the servo arm swinging through its arc is not enough to make any problem, and the balance cable is just a straight shot across the fuse.
