RE: rossi 61 df
Are you using the header tank on the bench? If not then it's the likely culprit. I've never messed with ducted fan engines but from all I've read the fuel usually has around 22% oil. It's wise to increase the oil anyway when not using nitro because of the leaner needle settings needed. I don't use nitro either and never go below 20% oil and that's with all castor too.
