RCU Forums - View Single Post - DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here
Old 03-30-2010 | 09:50 PM
  #309
typicalmale78
Default RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here
Order # yhst-17210252890263-121194
http://www.nitroplanes.com/gl603-8-a...srtf-blue.html
Hello,
Ijust ordered the product in the above link and during assembly I have found a problem. Ihad the battery charging while Iwas assembling the aircraft and before I installed the wing Idecided to connect the charged battery and check out all the servos and motors and such before finishing completely. My problem is that one of the ESC's seems to be damaged / broken. When Iconnect the battery it sounds like one of the ESC's has a constant beeping tone and the motor attached to that ESC "twitches." When I disconnect the motor from the ESC and connect the motor to the other ESC the motor works fine and there is no beeping noise or twitching. Also when applying throttle with the controller the motor attached to that ESC never rotates. I have checked the wiring and I can't seem to find anything out of place considering both ESC's jump off of the same main wires from the Rx. Iwould really appreciate any help and or info on replacing the damaged ESC considering it seems to be glued in place and the wires are soldered. Thanks in advance, Jeremy.
