RCU Forums - View Single Post - Carburator Screw
Old 03-31-2010 | 05:45 AM
Korps's Avatar
Korps
Default RE: Carburator Screw
ORIGINAL: bkdavy
You should try locktite on the screw before you try anything that will damage the screws. The carb should have two holes that correspond to the positions of the two screws you're pointing to. If those holes aren't lined up, the screws won't go in the full distance, and you might have stripped the threads trying to force the screws in. If thats the case, you'll probably need to tap the threads one size over and use new screws.
For future reference, most carbs have a throttle stop screw. Normally its located on the top of the carb on the same side as the throttle arm. Loosening that screw allows you to take out the entire barrel assemble, and is a much easier way to attach a z-bend. Then just reinsert the barrel and retighten the stop screw.
Brad
Okay I'm going to try locktite first. If that doesn't work then I will tap the threads.
Throttle Stop screw? Thanks I will definitely keep that in mind. I did try to loosten the throttle arm (did this with the 75), but it wouldn't budge and I didn't want to force it. So thats why I removed the carb. But thank you for the advice
