RCU Forums - View Single Post - pull pull elevator installation
Old 03-31-2010 | 09:54 AM
scottm50
Default pull pull elevator installation
hi - i'm going to install a pull pull elevator system in my cg super chipmunk - i fully understand the rudder pull pull set up but i'm not clear on the elevator set up ? do i install the servo on its side ? do i install the servo as normal and cross the wires ? use a vertical horn/cam system if yes how do i install it or is there another method - thanks in advance
