RCU Forums - View Single Post - Running prop with no spinner
Old 03-31-2010 | 10:47 AM
cfircav8r's Avatar
cfircav8r
Default RE: Running prop with no spinner
In your case it will work with or without, but if the engine is in a cowl such as a decathalon then a spinner should be used as it directs more air into the openings for proper cooling. Most modern full scale aircraft can not be run without the spinner for this reason. This is only a factor on true scale aircraft, but can be critical.
