RCU Forums - View Single Post - Wing tip stall
Old 03-31-2010 | 04:19 PM
tony0707
Default RE: Wing tip stall
HI ON FINAL THE PLANE WILL USUALLY DO A SLIGHT ROCKING MOTION IF YOU SLOW IT TO MUCHTHIS IS YOUR SIGN THAT THE STALL IS COMINGBLEEP THE THROTTLE JUST ENOUGHT TO INCREASE YOUR FOWARD MOTION AND THAT WILL KEEEP THE PLANE FLYINGALL WILL BE FINE ( INCREASING POWER CAN SAVE A STALL )- NEVER STOP TRYING TO FLY THE PLANE (NEVER NEVER GIVE UP) AND AN INPUT OF UP AT THE LAST MOMENT HAS VERY OFTEN SAVED MY PLANE-EVEN WHEN I THOUGHT IT CRASHED -I HAVE WALKED TO IT TO SEE IT SITTING ON ITS GEAR A HALF DOZEN TIMES IN 20 YEARS- AS THE PLANE SKIMMING ALONG THE GROUND IS ALWAYS BETTER THAN A DIRECT NOSE IN-FLY THAT THING EVERY MOMENT YOU CANI HAVE SEEN FRIENDS WALK AWAY FROM THE FLIGHT LINE ONLY TO HAVE THERE PLANE POP UP OVER THE TREES TO COMPLETELY SURPRISE THEMYOU GET THE IDEAENJOY REGARDS TONY
