RCU Forums - View Single Post - Motor surging
Old 03-31-2010 | 04:46 PM
Carpilot
Default RE: Motor surging
Maybe needle settings but if it idles good and transitions good it's already adjusted, also maybe diaphragm pump check valve in the carburetor may be worn a little, I have experienced that same problem before. check this thread out
http://www.rcuniverse.com/forum/m_7975257/tm.htm
It would surge just in the mid ranges Idle was good and top end was good. rebuilding the pump in the carburetor fixed the problem. see pictures.
