RE: Wing tip stall
the escapade is not known for having tip stalls.
It is however known for being lightly built and having the wing separate in flight at high speed.
If you want a plane that likes to tip stall try a cap 232. trick toavoid tip stalling is to make the final turn with 1/4 throttle and hold it until
your about 15 feet from run way then chop throttle and let her sink on in. Do not try to prolong the glide or it will then stall.
