RCU Forums - View Single Post - RC Pattern Flying now a sub-forum?
Old 03-31-2010 | 10:30 PM
DRC1
My Feedback: (10)
Default RE: RC Pattern Flying now a sub-forum?
ORIGINAL: AWorrest
I wasn't affected until tonight. I previously had four main forums listed, R/C Radios etc., R/C Gliders, R/C Pattern, and Electric Pattern. For some reason R/C Pattern and Classic Pattern are now subforums of R/C Gliders, Sailplanes, and Slope Soaring. This is possibly more than mischief than just streamlining the forums.
Allan
After testing and playing around with the Forum Subcription under our account, I observed the following...
...If you view all forums Pattern falls in line with Pattern Universe and list sub forums similar to Pylon Racing...
We are unable to select and hold the Pattern Universe check box. Once you hit submit, it is deselected...
Here is the observation that addresses the issue as <span style="color: #ff0000"><u>why many have Pattern fall into different forum headings</u></span>...Here is the answer after I performed a few tests...
...<span style="color: #0000ff">Pattern will always fall as a subforum under the next subscribed forum level up that is selected</span>...
This is very interesting. I presume that <span style="color: #00ff00">if RCU addresses the issue with not being able to select Pattern Universe, all will be solved and present better</span>...
Larry Diamond
