RE: SEBART ANGEL 50e
Flyboy she is a looker,last year I wanted to get the Angel ,but they were out of stock and got the Sukhoi instead which fly super. Well done SEBART!
Since I actually am more a pattern flyer I needed to get the Angel,what a beauty - and now I got one!
I use a 16 10 Xoar on the Sukhoi but will use the 16 10 APC on the Angel to get the spinner to fit.
You should check the weight of the batterie -mine is 630 gm and remember the Angel has a smaller wing so you dont want to use a batterie that is to heavy,more mah usually means more weight.
I will see how mine flys with above batterie and then decide on what more packs to buy to get some flying time-probably need 4 more packs.
