RE: New Byron 1.20 Extra 300 Project
Haha, I'm a loctite addict too! Use it on everything, even what I shouldn't. Once I red locktited (is that a verb?) the steel bolts used to mount an engine on to an aluminum engine mount. So a couple of years later I sell the plane and who says those bolts will release. Tried heat, WD40, cursing, nothing worked. Ended up cutting off bolt heads and replacing the mount.... Lesson learned.
