ORIGINAL: LNEWQBAN
Thank you, Davy; yours is awesome work.
I downloaded it today, and enjoyed it much.
However; I had to use the keys, which were way too sensitive for the Extra, especially the elevator key.
For some reason, my Futaba Tx did not work with the same cable it works with for FMS.
Any suggestions?
Again, thanks!
Hi,
does your controller appear in the game controller list in the Windows Control Panel (the exact location depends on your Windows version)? The sim works with joystick compatible controllers/cables. If it does, try calibrating it in the Control Panel. If not, you are probably using a serial or audio cable. In that case you'll need to install and config PICjoy (serial cable) or SmartPropoPlus (audio cable) and PPJoy. A nice explanation of these can be found [link=http://sim.tomsrc.com/page.php?17]here[/link]. These will emulate a joystick in Windows. Most USB cables will be recognized as joysticks from the start so should work after calibrating in Windows and configuring the controls in the sim.
Hope this helps,
Davy
