ORIGINAL: paladin
Kostas, are you going to use the EZ hinges or a Robart hinge point type? The hinge point would move the hinge knuckle out to the surface of the wing from the 1/8 inch below the surface with the CA hinges. The hinge point should work in the amount of wood needed for the CA hinge?
Joe
Joe i think i am going to stay with the supplied CA+ hinges /arrangement.
Although i really really hate the hinging-job they did.
I will stay for a while with this setup and if it fails on me (...hope it fales on the ground :P )
i will strip all the d@mn hinges and use my beloved and never failed on me Greatplanes hinges!
