Sky Scooter II
I painted mine blue on top with yellow wingtips. The underside of the wing and the tail feathers are also yellow. Flies great with the stock set up. I used packaging tape on the leading edges and wrapped around the nose. Also taped the bottom of the fuselage where it scrapes during landings.
I drilled holes in the foam for added air movement around the motor. Finally, I put a bamboo skewer vertically through the front of the wing to hold it securely centered in the fuselage.
