Brass gears are soft..
and they dont really last. If you take them of, they don't really work well again. I usually take a set of dikes and cut them off. If you cut along the teeth, not 90 deg. to the teeth, you will not damage the shaft cause the dikes will slip past it. Not bite into it.
PHIL I.
