RCU Forums - View Single Post - Angel S EVO Build Thread
Old 04-02-2010 | 11:27 AM
  #610
Max1965
Default RE: Angel S EVO Build Thread
This is my 4th Sebart plane and althought I didn't really like the looks of the plane after flying it I decided it was as pretty as an Angel.
I am using the Hacker A50-12s, 15/10 prop and 6s2p A-123 pack. The plane flies like it is on rails and I get about 8 minutes of pattern type flying time with 1 minute for landing. I do most of the pattern @ half throttle and vertical is decent.
I have used the A-123s in all the Sebart planes except for the large Sukohi. I like the A-123s because I need only one pack and I can recharge them in the plane @ 20 amps...full charge in 7-8 minutes. I don't need to remove the canopy to recharge the A-123s as I have a built in charge jack on the fueslage.
I did make a change on the rudder servo placement...........I installed the servo in the rear of the fuselage a little to the rear on on the other side of the elevator servo. I am not a big fan of the pull-pull system.
I think the plane is a keeper as are all the Sebart planes.
Edit:
Nealy forgot..........as with the other Sebart planes I have owned I always pin the hinges to the flying surfaces using toothpicks. I learned the hard way and damaged one of my planes when one side of my elevator pulled loose.
