RCU Forums - View Single Post - Official F27 Stryker Part 8: Beginners to Custom Darkness
Old 04-03-2010 | 06:23 PM
  #1235
moparmyway
Default RE: Official F27 Stryker Part 8: Beginners to Custom Darkness
ORIGINAL: louierc
Gryphon - let me look at the stock motor and see if I can get end caps off. If so, I can add some cooling holes. I have ordered the APC props. Mopar - do you have info on stock motor end cap removal and rework? Louie
You can easily pull off the caps. I use a knife and wedge between the cap and the housing, start wiggling and you will loosen her up. You could heat the can with a heatgun a little to help out.
Pictures coming in a few
ID:	1411120   Click image for larger version
