ORIGINAL: louierc
Well, I don't know what I am doing wrong, but I can't get the motor out of the holder. I removed the 4 screws at the end, can't see anything under the motor, but it is glued or wedged into the mount. I don't want to beat on the end of the shaft, but have unable to push it out with any tool. Are they glued into the plastic mount?
it is usually silicone that holds it in there. Easiest way to get her out is to remove all screws and twist the motor while holding the mount. That will break the silicone and usually will NOT damage the mount. you MUST be sure to remove all traces of the silicone before you re-install the motor into the mount.
Good Luck !!
