RCU Forums - View Single Post - Bobcat servos
Thread: Bobcat servos
Old 04-05-2002 | 05:59 PM
DavidR
Default Bobcat servos
I talked to the Tech goobs at Horizon this morning. I asked specifically about the battery voltage issue and they told me that the torque rating of the servo is at 6 volts. I also asked would the 5 cell pack be a problem and they told me no it would not. I then asked if this has been an issue again they said no. I have not had any problems (yet, and knock on wood) with the servos in my BC but this really concerns me. My gyro, and Vernon's was set up with the same kind of rates as you mentioned Tony. Maybe not quite 100% when the gear is down. And maybe slightly higher than 20% but not much. I have seen some jittering with a freshly charged pack with a big Giles I have with 5 cell packs but so far the BC has been rock solid. I think the disccussion about the Airtronics servos centered around the 3301/3321 servos and Bandit rudders.
David Reid
