RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 04-05-2010 | 10:35 AM
  #692
MTK
Default RE: SAP 180 (Syssa Performance)
ORIGINAL: cmoulder
ORIGINAL: MTK
Guys,
what if you got an appropriate length of 2 1/2'' PVC pipe from Cheapo depot, monokoted it, waxed it and then laid up some 3 oz glass cloth over that to cover around 200 degrees of circumference. This will weigh very little and you can make it as long as necessary
Matt
Sounds like a good alternative. Still would have to hog out the formers to make it fit.
You know, considering how quiet the fully enclosed pipe is in the Extra, maybe make a full enclosure for the pipe out of the 2 1/2" molding. 1/4" - 3/8" room around the piupe is all that's needed rfor cooling. It will actually work better than a fully exposed pipe. Air will turbulate better and remove more heat
